View Full Version : Konica Minolta 454e
antone
09-07-2018, 04:57 PM
Using coin op hook up...can the USB......option be disable! How can this to work with out free copies
Sent from my SM-N950U using Tapatalk
Synthohol
09-07-2018, 06:20 PM
Coin OP does not use usb. It uses a connector on the prcb board left side.
If your vending unit only has usb it's likely not for a konica at all.
blackcat4866
09-07-2018, 07:03 PM
I don't think that he wants to connect the coinop to the USB. I think he'd like to restrict use of the USB port to stop free copying from USB.
And you can disable printing and/or scanning from USB, but you may have difficulty figuring a way to make the coinop to charge for those functions. =^..^=
Synthohol
09-07-2018, 07:12 PM
If vendor mode is on you still can't print from usb.
I guess I'm not understanding the problem.
The front usb plugs into the mfp board outside the machine.
Just unplug it and tuck it behind a cover!!!
Very easy to solve if you just stop and think.
You can also disable everything from usb in admin mode and still be able to load movie data or drivers in service mode.
Antone, if you need a manual become a contributor here and I'll link you to my server.
mincopier
09-07-2018, 10:33 PM
Go into Administrator mode, User Box Settings and you can turn the USB ports of completely here. Scanning is off by default. If worried people will find out how to get in and revers it just change the Admin password.
