View Full Version : Miscellaneous Bizhub C754 Keep Showing Cleaning In Progress
Naveed Shahid
09-15-2018, 10:41 PM
Hello Every One
Bizhub c754 keep showing Cleaning In Progress After Finishing Print Jobs Some Time In Print Job Machine Stop Printing And Keep Showing Cleaning In Progress
I Changed Trasfer Belt And Disable Auto Cleaning Trasfer Belt But Still Same Problem
Plz Advise me
Reagards
Synthohol
09-16-2018, 04:13 AM
did you slide the shield over and clean the two windows over the sensors under the belt?
Naveed Shahid
09-16-2018, 08:53 AM
Yes i clean sensor still same
tsbservice
09-16-2018, 09:21 AM
Update the Firmware of the machine as KM should fixed this with GD1-70 version.
Naveed Shahid
09-19-2018, 12:01 AM
Thanks for solution
I update the firmware problem solved but now showing c1144 finisher type fs 534 before updating firmware finisher working fine now keep showing c 1144 after firmware update any idea
Synthohol
09-19-2018, 12:05 AM
check all the belts on the exit assy, ive had them slip off or even the clock disk falls off.
