View Full Version : C-4101 bizhub C220
aleksander
09-20-2018, 10:37 AM
Any have experience with C-4101 ini bizhub C220?
I've already replace PH unit & PRCB but still have the same error.
Any solution ?
Sent from my Lenovo K53a48 using Tapatalk
Synthohol
09-20-2018, 07:04 PM
Did you change the PH relay board as outlined in the manual?
A0EDH00200
aleksander
09-20-2018, 11:22 PM
A0EDH00200Yes and C4101 still occurred
Synthohol
09-22-2018, 01:32 PM
in service mode are you able to run load check?
Albonline
09-24-2018, 08:19 PM
fyi the c220 ph is not the same as c360 or c280
aleksander
09-25-2018, 09:28 AM
Solved. Harness & connector problem.
