View Full Version : Bizhub C550 color problem
rindraintsoa
10-09-2018, 10:09 AM
Dear All,
I have a problem with my C550 machine, as you can see in the sample page the machine print too much green, I have already changed imaging unit, transfert belt, laser unit but no change, does anybody send any suggestion. Thank you very much in advance.40800
Woxner
10-09-2018, 03:54 PM
have youi done the inialize and reset the gradation.
rindraintsoa
10-10-2018, 07:00 AM
Yes, I have changed everything without any good result (transfert belt, laser unit, HV1, HV2, etc). The problem still persist, does anybody have a suggestion?
Schneider
10-10-2018, 07:20 AM
Its very odd - tried a main board?
Phil B.
10-10-2018, 05:16 PM
you have too much CYAN ..not green. Y & C = G.
look at the dispensing ratios
mo0651
10-10-2018, 06:32 PM
I think Phil is on it. What have you done with the Imaging units???
Phil B.
10-10-2018, 11:43 PM
gradation adjust is not PARTS but a service mode function. replacing parts should be done AFTER calibrations/adjustments have failed.
blackcat4866
10-11-2018, 12:12 AM
So you're not even going to look at the consumables, like imaging units? In addition to cyan massively overtoning, magenta is massively undertoning. You must have been talking to the hotline: "Oh yeah, it's got to be a board..."
rindraintsoa
10-12-2018, 06:46 AM
Hi all,
I would like to mention that I am a field engineer so the first thing I have done was to change the IU. When I say green I understand that Green is mix of Cyan and Yellow. So any feedback would be much appreciated. Thanks all
Zesti
10-12-2018, 03:40 PM
Can you share level history1 and Table No. data.
Can you tell briefly describe history of what happened?
