View Full Version : Konica 6000 while adjusting printer gama sensor in quality adj. giving error 51
sadanand
10-10-2018, 06:18 AM
Hi friends
c 6000 giving error 51 while doing Printer Gamma Sensor Adj. giving error any solution all dev. are new
Schneider
10-10-2018, 06:54 AM
Manual is unhelpful with this one saying its had an error calculating the regressions on the test pattern and to "readjust" as the solution.
I always found these machines needed to be completely clean around the drum and developer units. As a first step I would be making sure it is clean around there and then go through the calibrations again.
A second though is make sure the test pattern is good and the scanner glass is clean too.
