View Full Version : Bizhub 454e Error C-E004
Zesti
10-12-2018, 03:55 PM
Hi guys,
This machine came to me, a along and agonizing history attached with the machine, somebody was talking about a mouse some posts back.
Anyways. The machine got ready, if go into service mode it gives away E004, say after about 3 mins or so, if stay on copy screen it gives message "An internal error occurred and will be restart"....
Any thoughts about that....
copyman
10-12-2018, 04:59 PM
I found this same issue on this forum, here is one example. There is probably more if you do a search.
C284e error c-e004 (http://www.copytechnet.com/forums/konica-minolta/104401-c284e-error-c-e004.html)
Zesti
10-19-2018, 03:20 PM
Hi guys,
Got that E004 issue, solved it...:o
FYI
The machine give away E004 after about 2 mins.
Noticed that the machine kept saying Preparing Scan/Box after some while it gives away code and in the admin settings NEtwork never shoed up and I was curious about that.
I formatted HDD to no avail.
Then did an NVRAM reset and reloaded FW.
Tadaa machine is working now without error.
But one thing noticed later, its not entering service setup..utility-counter-keypad S00S01 but nothing happens...
any suggestions or I have to dig in again...
Zesti
10-19-2018, 07:59 PM
Ok, the machine entered into service mode, s00s01, what I noted is that that the panel and touch screen respond a bit slow than normal..
Any thoughts..
blackcat4866
10-20-2018, 02:22 AM
I'd change the HDD. =^..^=
Zesti
10-20-2018, 07:56 AM
Yes I'll check the machine for couple of days....
