View Full Version : Jamming Bizhub c659 jam code 3205
tahashudin
10-18-2018, 05:45 AM
Paper jam at exit section ,test all tray papar passage aslso jam,check sensor
hgreeniii
11-01-2018, 01:33 PM
just had this same problem on a 958. The loop sensor now sits at the top of the registration unit. the spring on the actuator can come out of place and not enough pressure will be applied to the actuator.
3ktlc
11-01-2018, 02:24 PM
Yep, those spring actuators have done that before.
paulinho
01-10-2019, 12:58 AM
Hi All,
Was there a solution for this as I currently have a C958 presenting the same intermittent jam issue.
Loop actuator has been checked and is working fine.
Cheers
escalante
01-10-2019, 10:00 PM
I hope you can use the following technical bulletin of the Bizhub C458https://uploads.tapatalk-cdn.com/20190110/d73cf2c6aa91e5447d8068fa1dae0924.jpg41430https://uploads.tapatalk-cdn.com/20190110/ccf3253163e567cf902e648c91f3e66d.jpg
Enviado desde mi SM-J701M mediante Tapatalk
Phil B.
01-10-2019, 10:03 PM
Hi All, Was there a solution for this as I currently have a C958 presenting the same intermittent jam issue.
Cheers
START A NEW THREAD!
the machine and codes are different.. stop piggybacking your issue on someone elses.
kaisa
12-14-2021, 10:46 AM
i have the same problem (C759). loop sensor is OK.
how did you fix the problem?
REGSIS
12-23-2021, 07:00 PM
That should be jam on entrance of duplex section.
Duplex drive belt slips because there is no limiter on side of the gear.
I used to put a rubber cover which are used to cover holes for scanner transport screws (4&8 series).
Drill a small hole in it (it should be tight) and mount it on a shaft to make a limiter. Belt will never slip again.
I will post a picture if I still have it.
51221
Edit: Picture posted :o
White rubber marked with red arrow inserted to prevent belt from slipping.
izcuintle
06-26-2022, 05:46 PM
I had the same problem on 2 machines and by removing key item 31 A795897500 Neutralizing Brush from parts manual. the issue got resolved.53800
Albonline
06-27-2022, 05:07 PM
Hi All,
Cheers
it will function but its getting shorter. also check the one way roller driven conveyance roller on the right side . if the upper drawers run without jamming I would be looking for roller od shrinkage up the right side of the unit.
HuronMan
06-28-2022, 04:34 PM
Check for bound up bushings in the reverse unit.
