View Full Version : TASKalfa 3051ci developer or drum issue
zoraldinho
10-25-2018, 08:50 AM
Hi,
User sand me a sample.U89 A3 format.
I read about 3051ci problems with developers.
It seems to me like a drum. The copier has 140K.Reviews please.:D Thanks.
Has Been
10-25-2018, 10:15 AM
Hi,
Dirty Magenta Charge roller
itchyfinger@att.net
10-25-2018, 02:25 PM
agreed dirty charge roller clean all 4 of them while your in there and vacuum out the cavity. if you see blisters in the roller while cleaning it, replace it with the new style.
craigster
10-25-2018, 04:33 PM
Definitely charge roller!! after cleaning it do a laser clean also
drazen7777
11-09-2018, 09:00 AM
Hy to all
I would like to hear whats yours cleaning solutions for chargers ? Iuse some kitchen cleaner called Meglio , thats prooved for me as the best result in charger cleaning and removing dirt but i think it leaves some film of product after wiping it off , so i wipe with alcohol after. If i try with alcohol only it is hard to remove stuck dirt on chargers.
darry1322
11-09-2018, 11:32 AM
Hy to all
Damp cloth with plain water.
ntbann
11-09-2018, 04:00 PM
Agree. Water on a cloth works the best. Don't use alcohol. It deteriorates the rubber.
blackcat4866
11-10-2018, 02:15 AM
For years I've been using automotive washer solvent. Today I tried straight water and it works even better.
Has Been
11-10-2018, 12:07 PM
Unscented Baby Wipes
Dan J
11-13-2018, 04:18 PM
Replace or clean the charge rollers.
Hi,
Once , during my experimental phase I used hand sanitizer..did a great job cleaning, but a small dab was accidentally left on the roller for about 5 minutes. Cleaned it so well that the coating peeled right off. :o
