Is konica minolta 350 compatible with any of the monolta di models
  • DOE
    • Mar 2010
    • 258
    Wanted to see if the Konica Minolta bizhub 350 was compatible with any of the Minolta d i models as the Minolta Parts seem to be cheaper thank you
    • 14400
    Re: Is konica minolta 350 compatible with any of the monolta di models
    The fuser, drum and dev unit are different. Developer is different as well.
    DF has different model number but they are the same mechanically.
    Feed units are the same.
    Boards are different.
    • Zesti
      • Jun 2009
      • 308
      Bizhub 222, 282, 362 are directly compatible to 350. Older Di were 2010, 2510, 3010,3510 were better machines, didn't give away 2557. Mechanical is same, some difference in IU, though Drum blade same. The fuser rollers are different.
