View Full Version : Miscellaneous Bizhub 367 , Reset Tools
pinspin
10-30-2018, 07:26 AM
Hello . We did not find in Service Manual how to use Reset Tools . We will be grateful for any advices .
allan
10-30-2018, 08:25 AM
Use chips or replace the ICP's on the current chips. If you have a tool its probably a reset fuse. But no need to reset these units.
allan
10-30-2018, 04:41 PM
Oops reset like the software tool?
pinspin
10-31-2018, 04:30 PM
We need to reset the machine parameters (nvram etc.), exception for Total Counter.
allan
10-31-2018, 04:34 PM
Why? Wont an initialize do the trick?
allan
10-31-2018, 04:35 PM
Or is it a brick?
pinspin
10-31-2018, 08:28 PM
Or is it a brick?
The copier freezes sometimes.
acusso1234
11-01-2018, 07:59 PM
Are you sure?
I have a bizhub 287 asking for a new drum.
Do not display is the choice in service mode.
Manual states that there are two settings via soft switch to change also. Tried that but no go. Firmware is one year old.
Ideas?
Sorry to hijack the post.
Aldo
allan
11-01-2018, 08:15 PM
Are you sure?
Ideas?
Aldo
The switches needs to be changed before the life runs out.
allan
11-01-2018, 09:15 PM
Are there any error codes in history?
pinspin
11-02-2018, 09:14 AM
Nope
allan
11-02-2018, 01:37 PM
Disconnect HDD if installed to test and if you can swop out the ram. But firmware should be done first.
