C8000 - CMYK lines on trailing edge
  • dagoof
    Still learning...
    • 220
    I've got an issue with a C8000 leaving CMYK stripes on the trailing edge - could anyone advise what unit that would give that effect?
    I thought it may have been the registration roller needing cleaned (before 2nd transfer) but have tried that. Have also tried swapping out both 2nd transfer unit and main transfer belt unit.
  • khattab.al.masry
    • 212
    Re: C8000 - CMYK lines on trailing edge
    Originally posted by dagoof
    I've got an issue with a C8000 leaving CMYK stripes on the trailing edge - I've managed to narrow it down to the transfer belt assembly, could anyone advise what might be the specific cause within this unit that would give that effect?
    Samples please!
    Sent from my SM-J700H using Tapatalk
    • dagoof
      Still learning...
      • 220
      Spoke to soon - I'd swapped out the transfer unit and thought that was it gone but it's intermittent and back again!
      Sometimes it leaves clean straight lines, but other times it's dirty splodges (see attached).
      • sadanand
        • 62
        Check image magnification and image registration
        • dagoof
          Still learning...
          • 220
          Had already given top-side registration rollers a clean to no avail, so I just pulled out the whole unit and gave it an overhaul, that sorted it
