View Full Version : B554e no toner on page
rrrohan
11-09-2018, 09:11 AM
B554e prints nothing, copies nothing.
Drum and Dev changed as were due. no change.
Drum confirmed to rotate.
Stop mid print and no image on Drum
Load checked Laser (Print Head) and it spins up, so think thats fine.
Get no C codes just P codes due to failed stabilisation.
Im thinking either Print head or HV Board
Under time pressure to solve this, im thinking the HV Board, do you concur
thanks?
copier addict
11-09-2018, 01:43 PM
thanks?
If you had the transfer belt out I would make sure it is installed correctly.
Also check that there isn't something physically blocking the printhead.
HV board, as you stated, could also be the culprit.
allan
11-09-2018, 03:38 PM
no data to the print head does this on some KM machines
Zesti
11-10-2018, 06:47 AM
I hope you have re-seated HV and PH connectors already. If no result, try changing 1 by 1.
No data to PH is Worst case.:(
Zesti
11-10-2018, 07:07 AM
rrrohan
11-12-2018, 02:35 AM
Ended up being the high voltage board
CraigW
11-12-2018, 02:31 PM
Thanks for update....
JR2ALTA
11-13-2018, 12:14 AM
In my experience a bad HV board causes washed out prints not completely blank. So good to know, thanks.
rrrohan
11-13-2018, 11:01 AM
sometimes they just epicly fail and dont function at all i guess *shrugs*
hopefully it helps the next guy
