joaopauloooo
11-10-2018, 01:11 PM
I have this bizhub C220 printer that was working ok and then started showing some white marks on the Magenta Drum as you can see on Pic 1.
I have changed this drum and the problem stopped for a while, but then came back as you can see on Pic 2.
But the fact is that I took the older drum and put in another C220 printer and never got this issue on the other printer.
Then I simply swapped this new drum with the older and the problem stopped for a while and came back again.
So my question is, what could be causing this issue on the drum since this drum is working ok?
This is an A4 printed with 50% Magenta.
White bands are in main scan direction.
41070
Pic1
41071
Pic2
41070
Pic1
41071
Pic2
