View Full Version : Bizhub C3350 exit roller removal
copier tech
11-12-2018, 09:44 PM
Quick question please, exit rubbers have split & fallen out so paper doesnt exit very well jams or wrinkles so have ordered a new exit roller. My question is how does it come out!? No explanation in the CE manual.
Synthohol
11-12-2018, 10:51 PM
which ones? follow the clutch replacement on page g-61 in the SM to remove the exit unit. the scanner has to come off.
btw, can you just roll electrical tape on the crappy rollers?
http://www.copytechnet.com/forums/attachments/konica-minolta/41074d1542059487-bizhub-c3350-exit-roller-removal-exit-jpg
copier tech
11-13-2018, 07:46 AM
[QUOTE=Synthohol;711300]which ones? follow the clutch replacement on page g-61 in the SM to remove the exit unit. the scanner has to come off.
http://www.copytechnet.com/forums/attachments/konica-minolta/41074d1542059487-bizhub-c3350-exit-roller-removal-exit-jpg[/Q
Item 16 rubber has gone so just need that roller out to fit a new one, I did think about using rubber tape, but they are also used to pull paper back in for duplex not sure how reliable that would be!?
3ktlc
11-13-2018, 03:14 PM
Be careful taking the scanner off. Those ribbon connectors are very delicate.
