zstekovic
11-13-2018, 05:30 PM
Hello everybody!
I have Konica Minolta C654e with FS-535, SD-512 and PK-521 (2/3 holes) - it printed for whole 2 days at my office.
Yesterday I got error C E004, and because I'm not under contract (bought machine for cheep) repair cost 10x more than machine
(board replacement and stuff).
First I try holding reset and reset trouble codes - did not help - then I priced to see if memory module moved during move of the machine - no - it's fine.
Then I check all the board connectors that I could find, they are ok.
So I tray Stop 00 Stop 01, because I don't have anything to lose at this point.
Format HDD, check memory, initialize whole system.
In short, reset everything I could find, and error C E004 despaired!
Excellent!
+ HDD is OK
+ memory is OK
+ communication and copying SSD>HDD is OK
I reboot the machine, and I can scan and copy. That's progress.
But then:
ATENTION1
- Preparing SCAN/FAX
- Preparing User box
- Bypass Tray cannot be used (it's little bit wobbly on right/back side - I will check that later)
So I think that I need to reinitialize everything, and I need this forum help.
I can connect to web interface, but if i try to log in as the admin it say:
- It is not possible to login now.
I don't have any option to change network preferences in admin menu.
Also I needed to reset admin password in Tech mode with stop - zero (0) - C - 5.
Now I can login on machine as admin, but lot of panels are missing.
How screwed I'm?
Please help.
Thanks!
Excellent!
+ HDD is OK
+ memory is OK
But then:
ATENTION1
How screwed I'm?
Please help.
Thanks!
