View Full Version : Bizhub c35 0094 solenoid?
mrfuser
11-30-2018, 04:42 AM
Does anyone know the exact location of the sticky pad on the secondary transfer roller solenoid? Manual is vague it seems and Iím not sure if it is on the door under the transfer roller or where.
Albonline
11-30-2018, 02:17 PM
buried under the duplexing system, inside the door. fun.
srvctec
12-20-2018, 06:26 PM
The 0094 problem might just be that gears on that assembly are out of timing. Follow the procedure in the service manual for gettng them timed correctly. There are a number of other possibilities as well for the 0094 on these POS machines.
Synthohol
12-20-2018, 07:41 PM
0094 code articles.
allan
12-20-2018, 08:18 PM
Second file called 0094+error seems to be corrupt.
Synthohol
12-20-2018, 10:32 PM
yes, its corrupt online as well.:mad:
this one is the only other one that covers something else.
copyman
12-21-2018, 12:59 AM
Sorry wish I could be more help. Might be a waste of your time replacing that solenoid, after going through the hassle of replacing it the mach still threw the code.
This model is exactly why Kon/Min should stick with larger machines. This model was a flop, put in same category as the PP1300 series. Most of the good Kon/Min small machines are rebranded made by another OEM, one example comes to mind is Biz 25e which I believe is made by Muratec. A very good small box. Good luck
Vikingrepairguy
12-27-2018, 07:14 PM
We usually just replace the door section, only thing that sucks about that is the mile long wire harness!
