View Full Version : Miscellaneous Konica Minolta C224e Paper size detecting as 11x17
musthafavi
12-05-2018, 06:19 AM
Konica Minolta C224e from Tray2 Paper size detecting as 11x17
byronf
12-05-2018, 09:43 AM
[QUOTE=musthafavi;715208]Konica Minolta C224e from Tray2 Paper size detecting
Change parts below
41218
copier addict
12-06-2018, 04:42 PM
What size paper is in the tray? What have you done to troubleshoot problem?
tech51
12-06-2018, 05:37 PM
Usually a broken wire on the connector as it plugs into the size block. Easily repairable if you know how to use a soldering iron.
musthafavi
12-08-2018, 10:19 AM
Paper size in the tray : A3
Phil B.
12-08-2018, 09:35 PM
what have you done to correct the issue?
you need to provide more info if you want a resolve
musthafavi
12-09-2018, 05:02 AM
Thanks for your replay, the issue has been solved,
Feed roller has been changed and its working fine now
Phil B.
12-09-2018, 05:47 AM
ok a *TIP* anytime you have 'size mismatch' 'false/ghost jams'
AT LEAST CLEAN THE ROLLERS.. basics.. EVEN in the USERS manual!
allan
12-09-2018, 07:47 AM
Not that common but had that before where the wire breaks of right next to the connector.
Still not sure how a feed roller fixes a tray size detection problem??
Hate those timing jams J-99XX but it point you in the right direction if the machine tells
you to check paper size in the tray.
musthafavi
12-09-2018, 07:57 AM
you to check the paper size in the tray.
Before changing the feed roller, I cleaned the paper tray, feed roller and it keeps continue getting the same paper size
and finally, changed both feed roller and its working fine
Phil B.
12-09-2018, 08:19 AM
doesn't fit logic for me...
unless moving trays got a sensor working...
musthafavi
12-09-2018, 12:31 PM
Yes you are right, again its revert back to 11X7 size,
after restarting the printer its detect as A3, after a while or while loading new paper it's detecting as 11x7
Please need your suggestions and support to short out this issue, what I will do next
allan
12-09-2018, 02:43 PM
Eish... Its the Width detection sensor on the sensor holder its broken or the wire is broken use a screwdriver to remove the sensor holder to inspect the holder and the sensors the connector and the cable.
musthafavi
12-10-2018, 05:25 AM
could you please explain, where it is located in Tray2
allan
12-10-2018, 05:42 AM
If you remove the tray at the back inside the machine.
Could even find a piece of paper in there.
Phil B.
DONE WITH THIS CRAP.
