View Full Version : DEVELOP DRUMS 1060/1070
xeroxsharp
12-11-2018, 03:15 PM
Hi all,
I am a Xerox tech and I wonder, what is the difference between DRUMS develop drum DU105 and DU106.
Thanks to all.
Regards,
Mitja
Synthohol
12-11-2018, 07:35 PM
there is likely a flange and or hardware difference and could also be the coating of the drum as well.
for the price i woulnt risk it. id get whatever the machine calls for.
xeroxsharp
12-14-2018, 07:19 AM
Thanks Synthohol. My opinion is exactly the same.But I'm still interested in some other opinion.
Thanks again.
Gaffers01
12-19-2018, 03:09 PM
The plate at the backend of the drum is different, just swap it with old one and it works fine.
Takes about 10 minutes to do.
wjurls
12-28-2018, 03:54 AM
I convert DU-105's to DU-106's all the time. It takes 3 seconds with a pneumatic muffler cuttoff wheel.
I have attached photos. This process will save you about $100 each on a C1060L.
413454134641344
mastarad
06-07-2019, 05:35 PM
hello,
what is a real life of your du-105 drum? 100% is 410.000 copies. who print more, who print less?
xeroxsharp
06-14-2019, 05:37 AM
Thanks to Gaffers01 (http://www.copytechnet.com/forums/members/gaffers01.html) and wjurls (http://www.copytechnet.com/forums/members/wjurls.html) .
wjurls
07-01-2019, 05:03 PM
[QUOTE=mastarad;764935]hello,
what is a real life of your du-105 drum? 100% is 410.000 copies. who print more, who print less?[/QUOTE
They can make it to around 180%, 165% average, I would order replacement to keep on hand around 150%.
jpablo_mza
10-01-2019, 10:33 PM
I had to change two sets of Du105 with 100k for lines in the print, apparently it is due to a manufacturing defect, the manufacturing date is 01-19.
You who should be this possible
