View Full Version : C1070 registration swaying.
MVPunisher
12-11-2018, 06:15 PM
I have a c1070 that the entire image is swaying back and forth in the feed direction during printing. Classic registration clutch symptoms. However I have replaced conveyance clutch and pre-reg clutch already. Thinking conveyance drive board. Anybody seen this?
Toxic
12-11-2018, 08:22 PM
Try to disable registration swing and check is there some improvements.
On C1060l dipsw for this is 36-3
tsbservice
12-11-2018, 10:10 PM
Yes, not familiar with this model but would say to try adjustments of registration amount/loop through the service mode and see if it helps. Good point Toxic.
MVPunisher
12-13-2018, 08:10 PM
Heard a couple stray clicks going on. Found registration idler gear on front of conveyance unit had some worn teeth. Replaced the gear and all is fixed. Thanks guys.
blackcat4866
12-14-2018, 01:01 AM
Which gears? =^..^=
