n25an
12-25-2018, 02:13 PM
I reported to site twice and found machine down...
twice found a piece of paper stuck in finisher but once removed functioned like normal...
third time went to site... ran machine and noticed that when paper fed into finisher... it would hit a snag and bow and then the noise would start...
found a sensor flag was out of place... it was locked... and the paper kept hitting it and bowing...
did some research and found
a handout (http://www.copytechnet.com/forums/konica-minolta/134279-bizhub-3851fs-post713988.html#post713988) that details how to grease the finisher... internal finisher...
also found a firmware (http://www.copytechnet.com/forums/konica-minolta/134279-bizhub-3851fs-post716826.html#post716826) that deals with a jam code close to the one I was dealing with in finisher... just in case this was firmware related...
in case the flag was kept up by the firmware... stranger things have happened....
also found the jam code in manual c1140 that deals with the issue... it recommends parts...
I removed the finisher and greased the rods per the handout... in the process found some parts out of place... re-seated them
the flag... there was a giant bar with two paddles on it... they weren't connecting with the flag... so when the bar lifted the inner section... the flag did not move...
I installed all the firmware... beginning from the firmware following the installed all the way to the latest and greatest...
I re-seated everything... found more parts out of place.... re-seated a couple more times to get right...
its been working ok...
no parts ordered
.hope this helps someone....
no parts ordered
