View Full Version : Dead Machine Konica BizHub C3850 black screen
Jammed
12-26-2018, 07:22 PM
The call was for a blank screen. Arrived to find op panel dead. Black screen. Start button and power buttons are lit. Rebooted. Machine goes trough it's start up test. Seems to boot up, just a black screen. It is not the op panel as I first replaced that. Main Board? HDD?
Thanks for any ideas.
tsbservice
12-26-2018, 07:38 PM
These are known for control panel failures.
You may want fo check out this thread:
C3350 (http://www.copytechnet.com/forums/konica-minolta/102924-c3350.html)
Downunder
01-16-2019, 01:27 AM
First option is to swap out SSD card
A3GNR71033 ………….SSD Memory
mo0651
01-16-2019, 02:56 PM
NOOOOOO... Known Problem is the UK211 memory chip.:cool:
tech51
01-16-2019, 05:40 PM
Every black panel problem I and my colleagues have had has been due to the mfp board failing. There is at the moment however a problem with ssd boards, so replacing them together seems to be the way to go.
If random lines of buttons don’t work however, that’s the ops panel....
