View Full Version : Bizhub c253 copy
raveendrala
12-27-2018, 07:53 AM
I have 3 Bizhub c203 machines with copy issues. Please check attached document. Any help would be grate.
Thank you.
Toxic
12-27-2018, 08:19 AM
Try to do install procedure for machine like it is new out of the box.
What happened before this problem or you buy machines with this problem or some other scenario?
allan
12-27-2018, 08:50 AM
Try adjusting the <background voltage> margin under <image process adjustment> to a positive value for magenta incrementally till the "fog" is gone.
The drum is not keeping charge like in the old days and the IU M probably needs to be changed out.
raveendrala
12-27-2018, 09:39 AM
We imported used machines, we got 3 unit with above issue.
allan
12-27-2018, 10:00 AM
Oops sorry did not check the top pic properly.
But here I googled it for you sweetie.
Follow this manual.
Konica Minolta Bizhub C253 Installation Manual (Page 8 of 17) (https://www.manualslib.com/manual/1413934/Konica-Minolta-Bizhub-C253.html?page=8#manual)
