View Full Version : C224 orange light flashing
copyman
01-06-2019, 05:11 AM
Machine boots up normally to "ready to copy" screen, can access service mode, etc. but cannot do anything else like print test pages, format HDD, as long as start button blinks orange.
Haven't spent a lot of time on this machine yet but this is what I found so far. Upgraded customer and just got this back to shop.
Consumables set to NO stop in enhanced security mode. Drums are way past life and showing 0%. L-1, L-2, L-3, L4 warnings show if you touch oil can on display. Toner gauges show full but 3 toners are near empty.
Will L codes cause machine to lock up? Don't recall ever seeing an L code on a C224.
Before I put 4 drums & 3 toners in this machine would like to know it will fix it. Might just keep it for parts instead.
Firmware up to date but installed successfully again.
Thanks in advance
allan
01-06-2019, 05:53 AM
Check that SW 51 is set to 0C and SW 55 F0. Had that a week after an SSD change.
copier tech
01-06-2019, 11:47 AM
Hate to put 4 drums & 3 toners in this machine and still be locked up. Might just keep it for parts instead.
Thanks in advance
After you fitted the drums did all the L warnings disappear?
Also in CE mode reset the ozone filter counter, you could also turn the life stop off & see what the machine is asking for, maybe fuser or transfer unit.
copyman
01-06-2019, 03:24 PM
Thanks for the replies so far. For copier tech not sure what you mean when I fitted the drums, I have note replaced anything yet. Still original drums with 248k on them & L codes showing
copyman
01-06-2019, 03:25 PM
Thanks for the replies so far. For copier tech not sure what you mean when I fitted the drums, I have not replaced anything yet. Still original drums with 248k on them and "L" codes showing.
I guess what I really want to know is if the machine will stop working with "L" codes?
copier tech
01-06-2019, 03:35 PM
What did you mean by “Hate to put 4 drums & 3 toners in this machine and still be locked up. Might just keep it for parts instead.” ?
copyman
01-06-2019, 03:58 PM
Sorry I worded it wrong. What I meant was "before" I put new drums and toner in. I changed it in original post.
By the way does anyone know if I do put new drums in to test and it don't work can I use the drums in another machine and will it still reset drum count?
copier tech
01-06-2019, 07:30 PM
The image unit life count is held in the drum chip, so you can use the IU as a test.
copier addict
01-06-2019, 08:06 PM
There is a softswitch setting that allows you to test drums, fusers, etc. Without using this softswitch you will have to attach another drum chip because it will not clear the drum count on the machine you install it into next.
allan
01-06-2019, 08:34 PM
There is no inelegance on the these durms or dev tanks. Its not like the 452 and 352 machines.
All depends if life stop has been set or not. That is why i do the soft switches 51 and 55 one to set no stop and the other to remove messages yes it works just fine with L-codes.
like in my previous reply set the switch 51 to 0C and 55 to F0 and if its been set set then back to 00 cycle the power and set them back to 0C and F0.
They are only warning codes not error codes. Chip them or change the SMD fuse on the existing chips.
The the question does the engine continue to run? It could have nothing to do with the life counters.
Had a machine do that but could not keep up filling the waste box and never allowed me to use it.
There is a difference between ready top accept a job and ready to do the job.
Woxner
01-07-2019, 01:43 AM
Do a new release on the belt and fuser. Even though set to no stop.
Woxner
01-07-2019, 01:51 AM
Root Cause
1. Poor connection or failure of memory module mounted on MFP board.
2. A failed HDD.
3. Firmware bug.
4. Poor connection or failed Interface Cable. Also check these
copyman
01-07-2019, 02:51 AM
Friggin mice chewed the wires! Don't ask me why but something kept pushing me toward the mech counter. When I took the inside front covers off i immediately saw the mouse droppings and pee everywhere. Then I saw the counter wires were chewed completely through and several 5vdc chewed but not broken. Connected the counter wires to test and machine worked fine. Have some soldering and shrink tubing to do. First time I'm seeing damage from mice in a "4" series model. Apparently in this model the mice can use the front door to enter instead of sneaking in the back:cool:. Seems like only place they could get in was under front cover, control panel, toner/exit cover, & inside right front covers.
Not sure how the pictures below will come out. I always have trouble and had to resize them smaller.
allan
01-07-2019, 05:41 AM
Well that will keep you busy. Also never saw mice in these machines before.
Not that the info is useful but you can put a small value resistor instead of the mech counter. Or even just short the wires out! :eek:
copier tech
01-07-2019, 06:08 AM
Wow good find mice can get into the smallest of holes!
tsbservice
01-07-2019, 08:36 AM
Wow man, that's good instinct or in other words years of repairing machines pay off ;)
