View Full Version : Electrical M3040DN Keeps saying adding toner
copier tech
01-07-2019, 05:04 PM
Hi all,
I went to this one today, the fault was large white voids, the dv unit was empty I can see the blank area of no toner on the roller the machine is not asking for a toner.
I fitted a new toner the machine started to add toner but after 5 mins still asks for toner, powered off/on machine starts adding again then goes into a loop & asks for toner again!? Any ideas!?
Sayens
01-07-2019, 08:09 PM
Check the toner opening, had a few that it left a film over it, and also open and close the rear fuser door.
Kyo fan
01-08-2019, 07:41 AM
Replace the developer clutch.
41397
RobertOB
01-08-2019, 03:30 PM
Check for a Blockage in the Feed assembly (Hopper) as well. We had a similar issue in our shop a couple of months back, and the hopper was blocked and had to be manually cleaned out.
taskalfaman
01-08-2019, 03:50 PM
Two questions
-which toner you inserted
- which drum is inside the machine.
please take a pciture, most likely one of those is wrong.
copier tech
01-08-2019, 04:16 PM
Two questions
TK-3150 Toner & DK-3100 drum.
I can see the toner botter is not turning but the drive gear is!?
taskalfaman
01-08-2019, 04:21 PM
drum is wrong type
must be DK-3150.
have fun
copier tech
01-08-2019, 04:58 PM
drum is wrong type
must be DK-3150.
have fun
Is that right!?
Kyocera DK-3100, Drum Unit, FS-2100, M3040, M3540- Original (https://alfatec.co.uk/copier-printer-fax-supplies/drums/kyocera-dk-3100-drum-unit-fs-2100-m3040-m3540-original.html)
copier tech
01-08-2019, 06:47 PM
41397
I took the side panel off & could see this clutch driving.
copier tech
01-08-2019, 06:51 PM
drum is wrong type
must be DK-3150.
have fun
Thanks, I think this is where i've gone wrong, previous engineer ordered the wrong drum unit.
Correct dev is DV-3100 but drum should be DK-3150 where the logic in that!?
However can you explain in future how I know what drum to order, my country voltage is 240v (UK)
41401
taskalfaman
01-08-2019, 07:25 PM
Is that right!?
nope
DK-3100 => 2100 series
DK-3130 => 4X00 series + M3550/60 series
DK-3150 => m3X40 series
european market.
have fun
copier tech
01-11-2019, 06:54 AM
nope
european market.
have fun
Thanks for your help machine up & running now & a lesson learnt!
M3040iDN & M3040DN use different drum units!
