View Full Version : Bizhub C3350 cannot access admin mode or service mode
JasonSBE
01-22-2019, 06:51 PM
Hi all. My boss picked up a couple of preowned C3350's from a wholesaler. Unfortunately, the previous owner changed the admin and CE passwords. I know the 4 and 4e series machines had a reset tool you could get from konica to factory reset the passwords and wipe all data. I was curious if there is a way to reset these either through the menus or using a reset tool. Any advice would be great.
Synthohol
01-23-2019, 12:20 PM
if both were changed i believe you need to replace the MFP board.
mo0651
01-23-2019, 02:01 PM
That series actually would not let you in either mode if the firmware was not up to date. Have you tried going in the "back door"?:mad:
Coggers
03-07-2019, 08:37 PM
Hi how do you do the back door way?
Synthohol
03-07-2019, 11:13 PM
have you tried releasing the access lock?
4.1.3 Procedure for releasing access lock
1. Touch Menu.
2. Touch [Counter].
3. Touch [Keypad].
4. Press the following keys in this order.
Stop -> 0 -> 9 -> 3 -> 1 -> 7
(With this procedure, activate the access lock release timer to start timing.)
5. When five minutes has elapsed after activating the access lock release timer, the access lock will be released.
try the standard password after that.
3 wrong attempts you'd get locked out again.
