View Full Version : KM Bizhub C364e - Image Quality Block Colours
insigniawales
01-23-2019, 08:30 PM
Hi - I have a problem with a machine on block colours (not C,M,Y,K) I'm having Yellow/Cyan/Magenta Lines within a block of Grey / Orange / Green etc. I think its related to the drum units. No P-Codes displayed machine on 500k, Cyan and Magenta drum life near end (10%) 41513
Many Thanks -
Phil B.
01-23-2019, 08:36 PM
Many Thanks -
well you just stated the NEXT step... replace the M & C PCU
copier addict
01-23-2019, 08:51 PM
Clean the grids with the pull out wands and test again. If still no good replace colour drums.
Synaux
01-23-2019, 09:08 PM
Perform CMYK gradation & halftone tests. Then replace IUs a necessary.
:rolleyes:
Phil B.
01-23-2019, 09:10 PM
:rolleyes:
he will have to rerun adjustment after installing new IUs wont he?
insigniawales
01-23-2019, 09:23 PM
Many thanks for your contributions very much appreciated.
tsbservice
01-23-2019, 10:00 PM
What about posting consumables life? Dev units especially.
Print one color gradations etc. in service mode. What is done by techs?
insigniawales
01-23-2019, 10:06 PM
I will post these up tomorrow for you roughly 25% life on Devs will post gradiation c m y k etc
copier tech
01-24-2019, 06:23 AM
Many Thanks -
Are you new to this industry?
Run gradation prints for each colour this will point you in the right direction.
Dev units look ok but not enough to see from your sample.
But has the Develop already been replaced at least once? Usually towards 600k
Synaux
01-24-2019, 09:10 PM
Test prints, not adjustment! haha :P
Phil B.
01-24-2019, 10:45 PM
Test prints, not adjustment! haha :PSounds strange.
Most time when installing new pcus you have to adjust bias settings..
And WHY the fucking haha?
copyman
01-25-2019, 01:47 AM
Yeah I'm with Phil I don't get it. The drum with new chip resets count and adjusts / stabilizes automatically. But still should do manual "adjustments" when any consumables are replaced, Gradation adj, etc.
Synaux
01-25-2019, 08:26 PM
You don't get what? I merely suggested to perform test prints out of SM to identify exactly what IU(s) need to be replaced (which was suggested by copy tech as well). Depending on the situation, and PQ requirements, he might only need to replace 1 IU (as well as clean the PH as suggested).
You guys are confusing the hell out of me lol
insigniawales
01-25-2019, 08:31 PM
Replaced 3 Drums Today - Cyan Magenta and Yellow https://uploads.tapatalk-cdn.com/20190125/cb2940f2bde879977011feaba2c84ad9.jpg
Many thanks for your comments and suggestions.
Good to know for any other engineers experiencing same problem.
copier addict
01-25-2019, 09:45 PM
Sounds strange.
His first post was simply suggesting gradation TEST prints and you thought he meant adjustments.
He then corrected you still thought he meant adjustments.
So, that's why the HAHA.
