View Full Version : Bizhub 363 supply settings HP Web Jetadmin / FW ?
wrose51106
01-25-2019, 07:21 PM
Hello everyone -
I am attempting to monitor some Konica Bizhub 363's in HP Web Jetadmin software. The software is up to date. I have 2 locations, in location A tray 1 and 2 show supply levels only. In location B tray 1 and 2 also show, but so do drum, fuser, toner, itb and cleaning kit. I would assume the FW in location A is out of date? The local dealer says it is, I think they might be fibbin. Can anyone shed some light on this?
ROM Version
MFP Controller BOOT Program
A1UD0Y0-1E00-G00-02(00)
MFP Controller SubSet
A1UD0Y0-1F00-G00-04(00)
MFP Controller
A1UD0Y0-0100-G00-D6(00)
Operation Panel Message Data
A1UD0Y0-8100-G00-D4-00
Fax Board Controller1
A22M0Y0-4000-G00-06(00)
Fax Board Controller2
Scanner
A1UD0Y0-0023-G91-0F
Printer
A1UD0Y0-0050-G00-15
ADF
A1430Y0-0024-G00-12
Finisher
A0HR0Y0-0071-G01-07
Panel CPU
A0P00Y0-8900-G00-00
DSC1
DSC2
LCT
Loadable Device Driver
SD
Voice Data
Movie Data
Dictionary Data
OCR Library
MFP Controller System
A1UD0Y0-1000-G00-D6(00)
MFP Controller Print Controller
A1UD0Y0-3000-G00-67
MFP Controller Print Controller Font
A1UD0Y0-3F00-G00-0D
MFP Controller Print Controller Demo Page
A1UD0Y0-3E00-G00-00
MFP Controller MIO
A1UD0Y0-5000-G00-09(00)
MFP Controller PSWC
A1UD0Y0-5100-G00-10(00)
MFP Controller MIB IF
A1UD0Y0-5200-G00-00
MFP Controller IPP IF
A1UD0Y0-5200-G00-00
MFP Controller Outside Controller IF
MFP Controller TCP/Socket
A1UD0Y0-6300-G00-21(00)
MFP Controller OPEN API
A1UD0Y0-7000-G00-13(00)
MFP Controller Operation Panel
A1UD0Y0-8000-G00-D6(00)
MFP Controller CSRC Control Body
A1UD0Y0-8300-G00-01
MFP Controller PIC
A1UD0Y0-8200-G00-A5
copier addict
01-25-2019, 09:51 PM
The most current base firmware for the BH363 is G00-D6, which you have. There is likely some special firmware that is more recent, but it is only needed to correct specific issues.
copyman
01-25-2019, 10:05 PM
Agree with copier addict.The "latest" F/W for that old model is from 2012 !
Woxner
01-26-2019, 01:49 AM
end of life ius 2022
wrose51106
01-26-2019, 03:54 AM
Thank you all.
Any idea why only the trays are showing up in HP? All machines have the default SNMP v1 public / private.
Phil B.
01-26-2019, 08:01 AM
Thank you all.
maybe not all Admin settings.tabs are setup?
been too long for me to wipe cob webs
allan
01-26-2019, 01:14 PM
Have you re-flashed the machine?
Initialize the machine.
Think your MIB could be not the right one or the original.
Or the thing reading it is restricted from getting to it or certain parts of it. Could be private.
Could be a security setting.
Check all SNMP and MIB related stuff.
Try doing it with KM software. Pagescope net care.
wrose51106
01-27-2019, 02:32 AM
Go on, I am not familiar with this at all.
No I have not, we have about 30 at location A.
I have all machines on DHCP reservations and address books backed up, not a deal breaker to restore them. Local dealer might have a fit, cant blame them. I will need to locate a how to on initializing the 363.
I have a hard time thinking all 30 could be corrupted.
I thought this as well, I can not find anything to even remotely point to it though through the web interface or the local admin screen.
Done and done, it is set correctly, or the trays wouldn't read. We use SNMP v1 public on all print devices.
I will need to load a copy Monday to test.
Thank you all for the ideas!
allan
01-27-2019, 07:53 AM
No idea it was 30 units. Then really don't think its the machines at all.
wrose51106
01-28-2019, 04:53 PM
I went through stop - 0 - 0 - stop - 0 - 1
Under system 1 - I did an initialize. It did not fix the issue.
wrose51106
01-31-2019, 04:19 PM
When I go into admin settings, different machines have different tabs available, like there is supposed to be 10 tabs, 2 -5 - 8 - 9 are not available, is this what you mean?
wrose51106
01-31-2019, 04:26 PM
ROM Version
MFP Controller
Scanner
A1UD0Y0-0023-G91-0F
Printer
A1UD0Y0-0050-G00-15
ADF
A1430Y0-0024-G00-12
Finisher
A0HR0Y0-0071-G01-07
Panel CPU
A0P00Y0-8900-G00-00
DSC1
DSC2
LCT
SD
Voice Data
Movie Data
Dictionary Data
OCR Library
A1UD0Y0-3000-G00-67
A1UD0Y0-3F00-G00-0D
A1UD0Y0-3E00-G00-00
MFP Controller MIO
MFP Controller PSWC
A1UD0Y0-5200-G00-00
A1UD0Y0-5200-G00-00
A1UD0Y0-8300-G00-01
MFP Controller PIC
A1UD0Y0-8200-G00-A5
Here is the ROM info from the one that does report.
ROM Version
MFP Controller
Scanner
A1UD0Y0-0023-G00-0D
Printer
A1UD0Y0-0050-G00-15
ADF
A1430Y0-0024-G00-12
Finisher
Panel CPU
A0P00Y0-8900-G00-00
DSC1
DSC2
LCT
4348000-0050-G00-02
SD
Voice Data
Movie Data
A1UD0Y0-A000-G00-00
Dictionary Data
A1UD0Y0-B000-G00-0000
OCR Library
A1UD0Y0-3000-G00-67
A1UD0Y0-3F00-G00-0D
A1UD0Y0-3E00-G00-00
MFP Controller MIO
MFP Controller PSWC
A1UD0Y0-5200-G00-00
A1UD0Y0-5200-G00-00
A1UD0Y0-8300-G00-01
MFP Controller PIC
A1UD0Y0-8200-G00-A5
