View Full Version : BIZHUB C554
DarwLeo28
01-29-2019, 11:49 PM
Error code c-f907
someone has failed that failure41559
blackcat4866
01-29-2019, 11:54 PM
oh, my. =^..^=
Woxner
01-30-2019, 01:24 AM
try firmware first here is the bulletin
Error
Abort code CF907 and/or error code C6756. This may be indicated after MFP recovers from Sleep Mode.
Root Cause
Workaround/Fix
PROBABLE CAUSES:
1. Failed ErP board (PWB-DC assembly).
Check CN2 on ERPB for proper connection. Check CN2-1 and CN2-2 for 5V DC then check CN2-3 (Power monitor in) and CN2-4 (Power monitor out). If all voltages are present, replace the ERPB (p/n A161H00C02).
2. Possible loose connection/damaged wiring or failed board.
To troubleshoot check the following in order, and after each step, verify that the symptom is still present.
a. Harness connection between CCDB and SCDB
b. Harness connection between CCDB and MFPB
c. Harness connection between SCDB and DCPU
d. Harness connection between SCDB and PRCBIf errors reoccur, please consider replacing the following boards in the order listed.
CCD board (CCDB)
P/N MODEL
A161R72100 C554/C454/C364/C284/C224
A2X0R70000 C754/C654A2X0R70011 C754e/C654e/754/654/754e/654e
A61FR72100 554e/454e/364e/284e/224e
A5C1R70000 C554e/C454e/C364e/C284e/C224e
Scanner drive board (SCDB)
P/N MODEL
A161H01B12 C554/C454/C364/C284/C224
A5C1H01A11 C554e/554e/C454e/454e/C364e/364e/C284e/284e/C224e/224e
A2X0H01A12 754e/C754e/754/C754/654e/C654e/654/C654
Note: When the Scanner Drive Board is replaced with a modified one, please install a modified LED Exposure Unit at the same time. Please refer to attached Parts Bulletins for detailed information. To view the PDF, you may need to download a free copy of Adobe Reader®.http://cscsupportftp.mykonicaminolta.com/media/CPDocs/Reader.gif (http://www.adobe.com/products/acrobat/readstep2.html)
DC power supply (DCPU)
P/N MODEL
A161R7A300 C364/C284/C224
A61FR70000 364e/284e/224e
A5C1R70500 C364e/C284e/C224e
A5AYR70000 C554e/554e/C454e/454e
A2XKR71200 C554/C454
A2X0R70300 C754/C754e/754/754e/C654/C654e/654/654e
Printer Control Board (PRCB)
P/N MODEL
A161H00108 C364/C284/C224
A5C1H00102 C364e/C284e/C224e
A61FH00101 364e/284e/224e
A4FJH00104 C454A5C0H00101 C454e
A61EH00101 454eA2XKH00104 C554
A5AYH00101 C554eA61DH00101 554e
A2X0H00102 C754/C654
A2X0H00S01 C754e/C654e
A55VH00101 754/754e/654/654e
copyman
01-30-2019, 01:30 AM
Might not be the issue here but I always turn off the sleep mode on the 4 series. Mostly for losing connection. You have to go into service mode first and "permit", than in admin mode turn off sleep mode.
DarwLeo28
01-30-2019, 01:43 AM
[QUOTE = copyman; 724624] Puede que este no sea el problema aquí, pero siempre apago el modo de suspensión en la serie 4. Sobre todo para perder la conexión. Primero tiene que entrar en el modo de servicio y "permitir", que en el modo de administración desactive el modo de suspensión. [/ QUOTE]
where I find that option
copyman
01-30-2019, 02:50 AM
Since you are asking I will assume you are not a tech so I cannot provide any info on how to enter service mode. Perhaps see if you can find the service manual online or you can google how to enter service mode. Beware! if not a tech you can do a lot of damage in the service mode so proceed with caution! You will also need the passwords to enter the admin & serv modes to make sleep changes.
rrrohan
01-31-2019, 12:32 AM
Yeah same. Not waking up from sleep isn't a problem if it never goes to sleep.
tsbservice
02-01-2019, 08:20 PM
You guys mean to turn off/disable sleep mode and leave only low power mode? Or entirely leave the machine in Ready state.
I hope not otherwise Fusers won't last longer.
CompyTech
02-01-2019, 09:29 PM
This.. Those fusers will burn out quick.
copyman
02-01-2019, 10:08 PM
You can't turn off energy save mode, only sleep mode. Machines would not be able to get Energy Star certification if it was able to be turned off. It used to be 240 mins max for Energy Star now it's 60 mins.
