BH 750 doin wierd stuff....
  • excanonguy
    • Jun 2008
    • 173
    It started with a service call for a C-2807 error, rebooted the copier ,it printed out what was in the queue no problem, did a copy run no problem....few mins later I tried another copy run, it scanned the originals ,then it said wait warming up, in the print queue it said it was printing...had to re-boot the copier to clear this , it did this several times till finally it printed and copied...next day same thing... I am going in today to flash it ,it has old firmware on it ,but I just dont think that is the problem, I also checked the wall voltage and it stays steady at 117.4 VAC ,its at 119 VAC at standby, so I dont think its ac power related either...I am thinking perhaps hard drive, or maybe a faulty dc power supply?? Any ideas or suggestions greatly appreciated!!
  • RockETop
    Curmudgeon at large
    • Apr 2007
    • 171
    See if this thread is any help.
    • excanonguy
      • Jun 2008
      • 173
      Originally posted by RockETop
      I did go through that thread...but the machine has been working great since I flashed it!, It was an old version(17) so I had to go to ver 20 phase 2 1st then to ver 30 phase 3...its been a week now and the customer says it has been working great, and its a fairly high volume account, I am pretty sure its fixed but hey it is a copier!
      Steve
      • RockETop
        Curmudgeon at large
        • Apr 2007
        • 171
        Thanks for the update
        • excanonguy
          • Jun 2008
          • 173
          I guess I spoke too soon....this problem is back ,the machine seemed to work fine for about the last 6 weeks ....back to the same problem again...any ideas???
          • perdana
            • Jan 2008
            • 62
            TCSB Assy
            I think the prolem is Toner Control Sensor Assy Pn. 56AA-9100. Please change this board assy.
            • pepper38_cnd
              Field Service Manager
              • Aug 2005
              • 1075
              I had the same sort of problem, you'll see my post on that other thread. We ( I should say our KonicaMinolta Dealer Support rep ) got special firmware form Engineering in Japan it solved all our problems, it was released October 10 of this year, but I do not see it on the SSD. If you want to give it a try PM me and I'll send it to you.
              Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
              Now into Ip TV KODI Boxes
              • excanonguy
                • Jun 2008
                • 173
                Just an update I forgot to post but yes you are correct, the machine would not let me do any of the drum adjustments so we replaced the toner control pcb part# 56AA-9102E and the machine worked great, its been about 6 weeks or so and no problems! Not sure wher you are perdana, but I am in Canada which may explain the difference in our part #'s?
                • perdana
                  • Jan 2008
                  • 62
                  Tcsb board bz 750
                  Yes you are right pn. for this part is change to 56AA-9102E. I am in Indonesia, South East Asia Region.
