View Full Version : Miscellaneous Bizhub c454e can not access web browser
bratpit
02-10-2019, 10:04 PM
Hello i have a problem. My konica bizhub c454e can not access web browser. I tried several web browsers: chrome, firefox & IE. And also did a clear network data and problem still occurs. The machine CAN print, scan not working and cant access web browser. I also check other router to eliminate network and still no good. Help!
Print over network - OK
PING - OK
Scan - not working
Access over browser - not working (blank page, waiting to answer from eg. 192.168.0.77 - this is IP my c454e. Computer IP is 192.168.0.122, router IP - 192.168.0.100.
HTTP server on c454e is ON.
Any suggestions please?
allan
02-10-2019, 10:32 PM
Firmware updated?
Try changing IP's or omitting the router.
Phil B.
02-10-2019, 10:57 PM
PING - OK
Scan - not working
1) Scan to what?
Local server?
Email? **note known issues with S2E on win10/7 SMB issues - pretty sure on win server
USB?
Workstation?
2) If server: what OS version? Workstation: same.
3) Does error log show anything related?
Do they have an IT dept?
bratpit
02-10-2019, 10:58 PM
I changed the IP address and the problem is still there.
The firmware was not updated. Is it newer than the ones I have uploaded?
416734167441675
bratpit
02-10-2019, 11:01 PM
1) Scan to what?
Local server?
USB?
Workstation?
1. Scan to local computer.
2. OS on computer is windows 10.
3. How to check error log?
Phil B.
02-10-2019, 11:47 PM
3. How to check error log?From service mode.
Do you know how?
copier addict
02-10-2019, 11:57 PM
There is a setting in admin mode that allows PSWC
bratpit
02-11-2019, 06:08 AM
From service mode.
Do you know how?
I do not know. How can I view the logs?
tsbservice
02-11-2019, 07:04 AM
I would say that also, but in that case OP stated that cannot scan so I'm thinking about HDD.
Check in SM or admin mode that HDD isn't Unset or failed.
bratpit
02-11-2019, 07:27 AM
PSWC in settings is ON.
bratpit
02-11-2019, 07:44 AM
In SM HDD is not installed.
tsbservice
02-11-2019, 10:53 AM
Then go and set HDD in service mode. You may need to format it, movie data, FW etc.
Best case it will work once machine recognized it.
bratpit
02-11-2019, 12:04 PM
It looks like I do not have a hard drive installed.
allan
02-11-2019, 05:03 PM
So not HDD in the machine? Mmm wonder where it went.
bratpit
02-11-2019, 06:27 PM
Please, look.
What size (3,5" or 2,5") and what max disk capacity can be inserted into c454e?
4168641687
allan
02-11-2019, 06:51 PM
Please, look.
4168641687
Have you removed the covers to check? You could need the power cable.
emujo2
02-11-2019, 07:01 PM
All of KMs office equipment can operate w/o HDDs. We have some installs where the HDD must be rempoved prior to placement. Even though some functions may be lost, the web browser works in this config..The 454e is pretty old, you may just be using a browser that is too new to be supported (try running IE in compatibility mode). You could also do a network setting reset via service mode. Go through the admin settings to see if you can determine if SSL is on (TCP Socket Settings, Open API). When the HDD is not in use, the device will use a USB solid state drive (you may not see it) You should be able to go into service mode/state confirmation, page 2 and format the SSD. This would remove any installed SSL certs. You have mentioned several time that HTTP server is enabled so I don't think it's an admin setting blocking you. I'm only offering this as some help. It could also be firmware and the web browser portion is corrupt. Only other thing I can think of is you are running a gigabit network and the MFP can't communicate at this speed, try putting and old hub between the MFP NIC and the wall jack, or ensure your laptop NIC is running at no more than 100MB. E
bratpit
02-11-2019, 07:02 PM
I did not check. Will I find where the instructions are in which place is the hard drive?
allan
02-11-2019, 07:25 PM
Just remove the rear cover.
The HDD is probably there but not set.
The HDD should not affect the access to PSWC anyway.
Find a manual...
Phil B.
02-11-2019, 07:26 PM
location of parts in parts manual
emujo2
02-11-2019, 07:31 PM
If you bought this as a refurb and the seller did not tell you the HDD had been removed, I would go back to them and demand they fix this. If you bought as-is, you are probably better of without it..Once you get the HDD back installed, it will need to be formatted, and then you will start getting the "no movie data found" message, and you will be back here trying to find someone willing to supply it. If you wan to go that route you need a 3.5 SATA drive at least 250 GB, you will also need a data and power cable, the data cable is standard, but not sure you can find a power cable off the shelf. There is also mounting hardware that is needed unless you want the drive just hanging by the cables. E
