View Full Version : Jamming C227 / C287 jamming on colour (J30-03)
byronf
02-12-2019, 04:05 PM
Hi All,
I have a few of these on the field, we have been replacing fusing units prematurely due to the separation claws breaking. What I notice on these machines is that the client say the jam a lot when they print in color. So I have monitored a few of them and found J30-03 occurs frequently on the machine that break claw. It is obvious that the colour print stick to the fusing roller.
I have bumped the temperature up but have had no luck I even updated the firmware to G00-W2 with no luck.
If anybody has had this issue please enlighten me or if there is a part number for the claws.
Any advice will be appreciated. Thank you[/B][/B]
Brett GS
02-12-2019, 07:17 PM
Had this on a few.
Give you a call tomorow.
Toxic
02-12-2019, 08:18 PM
On what media and format this occurs?
I do not know if I'm doing wrong all the time but I think the fuser temperature should be lowered rather than increase to help paper not sticking in fuser...
blackcat4866
02-12-2019, 11:39 PM
On heavy fill images it helps to increase the leading edge void to 4.0mm - 5.0mm. If you duplex, the same applies to the trail edge void. =^..^=
allan
02-13-2019, 05:38 AM
Had this on a few.
Fix for the issue?
byronf
02-13-2019, 02:57 PM
This is on normal 80gsm bond. Tried losing the fuser temp as well and the issue still persist.
byronf
02-13-2019, 02:59 PM
Hi I will try this, however it my cause an issue on the field where end users my log calls for image not centralized.
Bix
02-13-2019, 03:22 PM
What is the page counter?
byronf
02-13-2019, 03:42 PM
13355 clicks
But bare in mind that this issue is an intermittent problem across all my machine's
allan
02-13-2019, 05:41 PM
Then its damp paper?
byronf
02-13-2019, 05:55 PM
At first that what the techs kept advising the client, until I bought the one machine in and used it daily for office use to test.
Bare in mind these machines +/- 600 belong to one client and 60% of these machines all the end users are complaining about the jamming only on colour prints
blackcat4866
02-14-2019, 02:09 AM
Can you try rephrasing that? I missed the point. =^..^=
byronf
02-14-2019, 03:54 AM
We have checked the paper for moisture and the problem still persists.
We have about 600 of these machines in the city council and they are all doing this.
I have brought one of the machines into our office that we are using daily for testing purposes and it intermittently jams only on colour prints.
blackcat4866
02-15-2019, 12:48 AM
I'm not going to try to convince you. You can make the adjustments or not.
I don't really care if you have 6 machines, 60, 600 or 6000. That doesn't change the answer. =^..^=
byronf
03-22-2019, 04:42 PM
Hi All,
This issue has been resolved.
I used separation fingers from C454e to repair the fuser.
Changed warm mode to 4
Put toner save mode on
It has been a month and the client has not had any issues
Thank you all for your help much appreciated
