View Full Version : Bizhub fs-533 motors?
mrfuser
02-20-2019, 07:24 PM
Does anyone have these or know if they are the same on other finishers?
A2YUPPT400 Stapler Movement Motor
A2YUPPW300 tray lift up motor
Bix
02-21-2019, 08:30 AM
Hi, can I ask you why?
I had an alleged problem with those pieces. In fact, I later discovered that a photointerrupter sensor did not operate them.
mrfuser
02-21-2019, 09:32 AM
Getting 1102 code. Stapler operates upon boot a couple of times then goes into code.
Bix
02-21-2019, 10:43 AM
Ok, my mistake, however, I get stuck immediately at the first print.
Then I would exclude that sensor but I would take into account the finisher board.
mo0651
02-21-2019, 02:21 PM
After a cross reference search, They are unique to that finisher.:(
The error code is for tray up/down movement.
korthr5
02-21-2019, 03:00 PM
A2YUPPT400 Stapler Movement Motor - FS-533 and FS-538
A2YUPPW300 tray lift up motor - FS-533 and FS-538
Synaux
02-23-2019, 03:27 AM
Not sure how difficult this is to take off without looking at it, but I have a fs533 for parts--willing to sell motor if interested.
mrfuser
02-23-2019, 06:06 AM
Where located?
Synaux
02-23-2019, 09:09 PM
Where located?
Texas
mrfuser
02-27-2019, 09:41 PM
Why is the error code for a tray lift motor when the trade does not lift?
Bix
02-28-2019, 10:38 AM
Does it make a small movement or absolute zero?
mrfuser
02-28-2019, 10:59 AM
None that I see. It’s the small internal finisher. The stapler tries its staple a few times , stops then pauses and error code.
Bix
02-28-2019, 11:20 AM
today I had a code C-1106. I removed the side covers and I pushed the stapler at the bottom. Now the code does not seem to appear.
I advise you to do the same thing for the tray. If you can manually lower it completely, the problem could be solved without replacing anything.
mrfuser
02-28-2019, 11:51 AM
Ok all, small internal finisher here, FS533. The exit tray is stationary and NOT a moving part that I can see so why the 1102 code?!?!? Not , 1106 or 1101 or any other code.
copier addict
02-28-2019, 02:23 PM
The exit tray is definitely a moving part. It raises and lowers. That's why the 1102 code. Look closer, maybe remove some covers.
Bix
03-01-2019, 09:45 AM
Exactly, the tray is movable but when it hangs it is very rigid, especially when it is lifted.
As soon as you unlock it initially, then it goes down / rises without problems
mrfuser
03-01-2019, 08:13 PM
Ok tray seems to move and now throws c-1109 code!?!?!!
looks like the staples are just getting stuck when it tries to load them and they pile up inside the stapler
