View Full Version : Lu-302 Large Capacity Unit
Cliff12341
02-21-2019, 08:49 PM
Lu-302 connected to a c659 Konica Minolta. When attaching these two together, there's 3 data cables that need to be connected. One of them requires a cable adapter that allows two 5 or so pin small male ends to connect. Somehow ive lost this small adapter. Do you have any advice on how to find this part online or how to order it? Any advice is appreciated, thank you.
907tec
02-21-2019, 10:25 PM
Not sure how to find that P/N, but if I were you I would just grab any old 5+ pin connectors and replace the existing ones. As long as it's only 5 wires, shouldn't take long at all.
Synthohol
02-21-2019, 10:43 PM
what are you talking about? there are 3 wires and a ground. its a direct fit, there are no adapters.
see page E-5
please explain.
41798
Cliff12341
02-21-2019, 11:06 PM
see page E-5
please explain.
41798 I'm sorry it's an lu-303 not a 302 that's my bad. In the parts manual for the 303 and the 659 it doesn't even show the adapter, but there is one there. The part number for the entire wiring assembly is A796N10400 and labeled "PFU Wiring" in the 659 parts manual. I was trying to see if I could get just the adapter and not the entire wiring assembly though. Thanks for your time.
Synthohol
02-22-2019, 05:25 AM
the male to male connectors come on the copier, if you lost one steal one from another copier that does not have an LU unit.
in my desperate days ive straightened out staples and connected the wires like the adapter would have (minus the plastic) and taped it up.
im sure you can find a similar one in a scrap finisher maybe?
Phil B.
02-22-2019, 07:37 AM
MacGyver 101! kudos! I used paper clips.. but it all works!
