View Full Version : konica Minolta Bizhub 211
karthik_tcp
10-04-2008, 06:10 AM
in bizhub 211 the display comes erratically. the company advice me to updte the firmware. but i could not bale to do becuase the usb port is not detected by the computer. i tryed with 3 computer. is there any other solution to update firmware or to make detect the usb port. Kindly advice me.
thanks and regards
S.Karthikeyan
vale24
10-04-2008, 05:02 PM
Hi, I think that you have an elektrical problem (something in power supplay). If you have other 211 you can change the power supply board and see what will happen.
Regards
Valentin Georgiev
Check & test the power supply board, control panel board, PWB-A & the port interface card. Much better if you will install those boards to other unit just to be sure.
ni311
10-06-2008, 03:36 PM
Did you try with two different USB cables?
