View Full Version : C360 adjusting fuser temperature as it relates to wrapping lower fixing roller ?
Intermittent wrapping the lower roller on a Konica C360 . Not sure if fuser temperature change will correct or just making a Thick paper change will correct fusing issue ?
slimslob
03-01-2019, 11:48 PM
You have posted in the wrong forum. Post your problems in the correct Technical Forum not the System Forums.
Phil B.
03-02-2019, 01:16 AM
http://www.copytechnet.com/forums/misc.php?do=vsarules
blackcat4866
03-02-2019, 01:28 AM
If it's heavy fill images check that your leading edge void is 4.0 to 5.0mm. If duplexing, also 4.0 to 5.0mm at the trail edge also. =^..^=
