View Full Version : 3500i missing options in service mode
docresources
03-02-2019, 07:32 PM
Have a 3500i that when you go into service mode u508 through u900 are missing. I have upgraded the firmware to the latest. Any help would be appreciated.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Phil B.
03-02-2019, 09:42 PM
was it working before the update?
what version did you use?
any errors or power failure during process?
docresources
03-02-2019, 09:44 PM
They were missing before I upgraded. That's why I upgraded it.
copiertec
03-02-2019, 10:04 PM
Have you tried a U021 (return to factory defaults)?
blackcat4866
03-02-2019, 11:00 PM
Take a look at the manual. There are no simulations between U508 and U900. There's nothing to find.
docresources
03-02-2019, 11:16 PM
Take a look at the manual. There are no simulations between U508 and U900. There's nothing to find.Well I'll be dipped in shit and called a turd lol, he's right. This is the first kyocera I have run across that doesn't have them. Ok so then how do you clear the fax dim.
blackcat4866
03-02-2019, 11:37 PM
According to the fax setup instructions U600 ... hmmmm?
Santander
03-03-2019, 12:06 AM
Do you have a fax option Installed? If the unit does not have a fax board installed the sim modes 600 plus will not display as there is nothing for the unit to do. If a fax option is installed, I would try to reseat it, otherwise you have a bad fax board that the unit is not recognizing.
