View Full Version : Bizhub c224e faint COPIES/SCANS
Konicatech
03-06-2019, 01:05 PM
Hello
have a c224e that is printing 100% fine except when you copy/scan from the glass/adf the output is faint on the top half of the page, and fine at the bottom.
changed CCD so far and problem still persists
cleaned mirrors still the same.
Anyone ever had a bad lamp under the glass?
mo0651
03-06-2019, 02:56 PM
Maybe the mirrors got moved out of alignment?
allan
03-06-2019, 06:50 PM
Give the front left unsupported corner a tug upwards and see if that helps.
Konicatech
03-06-2019, 07:01 PM
What would that do?
Cheers
copier addict
03-06-2019, 07:11 PM
Hello
Did you clean the underside of the platen glass?
Konicatech
03-06-2019, 07:21 PM
Yes, machine is very clean now! Glass, mirrors, ccd everything
copier addict
03-06-2019, 08:06 PM
Can you post a sample?
wjurls
03-06-2019, 08:07 PM
Scan a 2 sided original in 2-2 mode and see if both sides do it. The C224e uses a backside scanner in the RADF unit to read the back of the image and not the ccd. This will help narrow down where the problem lies.
allan
03-06-2019, 08:24 PM
What would that do?
Cheers
If nothing else a bit of exercise.
Users at the machine would lean heavily on that corner causing it to sag like old tits.
tsbservice
03-06-2019, 08:32 PM
Good catch but that really depends on what DF machine has DF-624 or DF-701.
wjurls
03-06-2019, 08:34 PM
That's right.. I forgot that dual scan was an option not standard..
Ado Mmoloki Moepedi
09-28-2023, 10:42 AM
Did you ever manage to slove the problem?
