View Full Version : Vertical Bands C1070
ttopman
03-12-2019, 11:09 AM
42021
Hello guys,
I need help with this I started getting two vertical lines a cross all pages on Yellow and Magenta lines. Drums are at 21%. Shortly after this, error C4631 began to pop up.
Any ideas how to resolve this?
Phil B.
03-12-2019, 05:28 PM
42021
Hello guys,
looks like a M dev unit
Toxic
03-12-2019, 06:48 PM
What is distance between this white void areas?
Approx 188mm pitch: Damage on the drum surface
Approx 44mm pitch: Developer conveyance failure of developing sleeve
blackcat4866
03-13-2019, 12:22 AM
Yup, I'm thinking drum too. =^..^=
Phil B.
03-13-2019, 12:35 AM
Yup, I'm thinking drum too. =^..^=I thought I saw LEF Feed. Am I wrong?
blackcat4866
03-13-2019, 12:42 AM
I viewed this print as Ledger (11 x 17) or Full Bleed (12 x 18), SEF. Super B+ (13 x 19) would have larger voids. These are the typical paper sizes used on the presses. =^..^=
Phil B.
03-13-2019, 01:14 AM
well I can't remember the last time I didn't agree/digress to your views BC.. so put another one in the "W" column
Synthohol
03-13-2019, 11:22 AM
near the bottom of the voids there seems to be a mark that may be foreign material stuck somewhere that pushes the mag roller back momentarily?
ttopman
03-13-2019, 04:47 PM
Measured the lines, it's approx 88mm gap.
I have this on Yellow too. Dev mag roller shows no sign of failure.
Find this very annoying
ttopman
03-13-2019, 04:51 PM
We've had the drums checked. There was some artifact there, had it removed at the expense of the drums. The problem though is that I have this on Yellow as well, the yellow drums are clean and good.
blackcat4866
03-13-2019, 04:53 PM
I've had my share of invisible drum flaws. Swap the drum to another color. If the flaw follows, replace it. =^..^=
tsbservice
03-13-2019, 06:16 PM
So sample is A4 size, lines are in parallel with feed direction, right?
ttopman
03-13-2019, 08:51 PM
Print is 12x18. Yes in feed direction
tsbservice
03-13-2019, 09:31 PM
Sample Full Bleed 12x18 and distance between white bands is ONLY 88 mm. And in feed direction?
Somehow hard to believe that from what we can see. Are you sure distance isn't 188mm?
Go swap drums and report back.
ttopman
03-21-2019, 02:53 PM
Changed the drums. The gaps are gone. It was invisible drum damage.
Thanks everyone.
blackcat4866
03-21-2019, 03:18 PM
Thanks for posting back. =^..^=
