View Full Version : konica 224 dots
lucycopy
03-22-2019, 02:58 PM
good morning
I have a konica c224e that both in print and in copy does the following defect.
I replaced belt, drum, developer, fuser, transfert roller but I didn't solve the problem
what can it be?42141
allan
03-22-2019, 04:38 PM
Try the laser from another machine.
lucycopy
03-22-2019, 05:07 PM
but it does bw and colored
however I try
srvctec
03-22-2019, 10:14 PM
however I try
Are you a tech? If not, take the suggestion from the tech who already answered your question (allan) with a possible solution. If it works, your problem is solved. I never understand people coming here for free advice and then refuting that advice.
Before trying a laser from another machine, I'd first re-secure the memory if it's installed, then re-secure all plugs to all main boards on the machine.
rrrohan
03-23-2019, 03:28 AM
the fact line are diagnal atleast means you can rule out ITBU, ITRU, DR and DV.
Does seem like laser is most likely.
I havent got the manual open atm but it might even have a suggestion in the image defects section
blackcat4866
03-23-2019, 03:59 AM
If I did that correctly in Adobe Reader the interval is 108.20mm or 34.44mm diameter roller.
My guess is that might be the diameter of the facing roller inside the primary transfer belt. If I'm correct you should see perforations or texture in the transfer belt. =^..^=
rrrohan
03-23-2019, 04:07 AM
so they are not diagonal?
was this portrait or landscape orientation in tray?
blackcat4866
03-23-2019, 04:09 AM
It's A4 ... my guess is SEF based on the color and pattern of dots. =^..^=
JR2ALTA
03-23-2019, 08:12 AM
"I replaced belt, drum, developer, fuser, transfert roller but I didn't solve the problem"
blackcat4866
03-23-2019, 01:45 PM
Do you have an opinion?
You must know by now that I'm a skeptic. I believe about 10% of what I read. =^..^=
allan
03-23-2019, 03:07 PM
True.
Fixed these spots before, for the life of me can't remember what i did.
JR2ALTA
03-23-2019, 07:06 PM
I just find it odd that those who insist on knowing what's been tried then disregard that very information.
lucycopy
03-25-2019, 12:45 PM
I'm a technician
even the laser change didn't work.
