View Full Version : C654 image shift
Brett GS
03-25-2019, 08:04 PM
Hi all
I got a C654 the has a image shift issue when printing on thick stock (300gsm so in spec).
Fuser is fine, changed main drive unit (even though no P codes),transfer roller,belt is still new.Adjusted fuser speed up and down but same result.
At first i thought it was the paper but got paper from another customer who also has a C654 and no issues.
Next thing i am going to try is the transport/conveyance unit in the door.
Am i missing something??
tsbservice
03-25-2019, 08:33 PM
Did you try bypass separation roller adjustment, there are two positions.
allan
03-25-2019, 09:42 PM
So the color registration is fine?
Is the shift consistent?
Arcadian
03-25-2019, 10:17 PM
AS ANY GOOD TECH WOULD SAY
do you have a print sample???
hehehe
Clean those rollers and clean them good. Which tray are you feeding from?? The registration roller could be suspect in this case. ive seen bent out of shape entry points could be binding on one side, check those springs which holds the rollers down. one might be worn or came off. i had a few like that. they just pop right off from the shaft.
good luck
blackcat4866
03-26-2019, 12:22 AM
IIRC there are specific image registration adjustments based on paper source and media type. In other words you can adjust image registration differently for 300 gsm media or bypass tray, or some combination. =^..^=
Brett GS
03-28-2019, 08:29 PM
Update
The conveyance/registration unit sorted issue out.
