View Full Version : ISW on 4 series and above
rrrohan
04-08-2019, 04:45 AM
Trying to get ISW to work again.
Havent used it since C360 days.
Back then it was just a .tar file that you needed to point to.
Now since all the files are extracted onto a USB, what file do I point to?:confused:
B0265
04-08-2019, 01:25 PM
I also havn't used the procedure for many years, but it's described in the service manual how to create the .tar file
antone
04-08-2019, 01:56 PM
Still tar file
Sent from my SM-N950U using Tapatalk
Synthohol
04-09-2019, 01:06 PM
no ISW anymore for a while.
just extract the files on to the root of the flash drive and boot with it plugged into the covered service port in the back.
rrrohan
04-09-2019, 03:16 PM
Had a c458 that didn't want to take firmware and it reminded me of how in the past I would use ISW instead.
Thanks for info. I'll try get it to work again
darry1322
04-09-2019, 03:22 PM
Press and hold the stop button while you power on the machine to enter firmware screen.
Copy the FW0002 folder to the root of a clean drive and insert the drive into the side usb port ( the one used to print from or scan to usb).
Synthohol
04-09-2019, 04:47 PM
thats the 8 series not the 4 series (just for clarification) 8 series the USB goes in the control panel USB and the 4 series its a USB service port on the side of the MFP board hidden by a plate and screw.
darry1322
04-09-2019, 06:28 PM
Yep. He last posted he was trying to do the firmware on a C458 so I wanted to make sure he was using the correct procedure for the C458.
tsbservice
04-09-2019, 06:36 PM
Regarding C458 that didn't want to take firmware-check machine for incorrect placement of front USB cable.
Woxner
04-10-2019, 12:24 AM
on the 4 series all you need to do is copy all the files in the folder. the folder ends in (00)
JR2ALTA
04-10-2019, 02:41 AM
What genius at Konica decided to "de-simplify" their firmware procedure? Why not bring back the CF card
rrrohan
04-10-2019, 02:46 AM
I tried plugging direct to the front USB port on MFP too.
Synthohol
04-10-2019, 04:25 AM
what kind/size flash drive?
4G or less i hope.
rrrohan
04-10-2019, 09:23 AM
Not sure where KM think we are shopping if they expect us to find 4GB or less.
But I got a 8GB old faithful.
But in this case I forgot to bring it and the crappy grocery store selection it just didn't like.
It was more the fact I want to start using the tools KM provide like remote deployment and ISW
