View Full Version : C3851 fs
CloneTJ
04-08-2019, 03:04 PM
Does anyone know if there is a way to run the c3851fs without the internal finisher?
3ktlc
04-09-2019, 02:09 PM
Try service mode. System 1. Unit isolation. There must be another way though. In Europe, the finisher is an option.
rrrohan
04-09-2019, 03:24 PM
You just physically remove it.
Is it causing problems?
copier addict
04-09-2019, 03:44 PM
What have you got against this cheesy, incredibly flimsy marvel of modern engineering?
Albonline
04-09-2019, 08:17 PM
just an fyi the 3850fs finisher will plug in and go. there are bulletins about these units, in a nutshell remove, disassemble,CLEAN,and lube the rails and things that move on them with drysurf. i have had good luck fixing these by doing this. i in the past have used plusguard also with good results.
Woxner
04-10-2019, 12:21 AM
you can just disable it and will just pull the copies out yourself. same as last post said isolation.
