View Full Version : Konica minolta Bizhub C 252
Nazakat
10-07-2008, 12:17 PM
Hi to all
Can anybody tell me how to reset transfer unit in Konica Minolta C 252?
Thanks in Advance
dogsbody
10-07-2008, 12:55 PM
replace the fuse. it is a 80mA glass fuse but i have used 50, 80 and 100mA.
Nazakat
10-09-2008, 12:47 PM
Dear Friend,
I have worked alot on toshiba but on Bizhub i am new.Please guide me where can i find the Fuse? i took out the transfer unit but couldent find the fuse.
dogsbody
10-10-2008, 06:16 AM
imagine the transfer belt in the machine, it should be on the right at the front. there is a small cover that comes off and it is under there.
ni311
10-10-2008, 03:18 PM
http://www.copytechnet.com/forums/konica-minolta/11366-bizhub-c-250-transfer-unit.html
Nazakat
10-22-2008, 08:35 AM
Dear Friend,
I have replaced the fuse of Transfer belt but after that it start giving Code C-2451 and stuck.I tried to place fuse 50ma,80ma and 100ma but to no avail.What else i can do to reset it.
ni311
10-22-2008, 05:29 PM
Did you try to reset the code?
Start from main power with the utility button holded down until trouble reset pops up on the display, touch the button, turn it off and then on.
Nazakat
10-23-2008, 06:13 AM
Friend,
I did that but when copier reaches to Stablizing Images it gives that Code Again.
Recheck the ITB. Check the how ITB lays on its position. This works 100% so it looks like u didnt place fuse correctly and check metal connector of ITB and the machine
please talk to me what replace fuse.
Hi to all
Thanks in Advance
You need to replace a special fuse on the front side handle of the belt unit, behind a little black cover.
