View Full Version : 8 series intermittent jamming from all trays
tsbservice
04-25-2019, 07:49 PM
CAUSE: Paper feed roller (p/n A00J563600) is slipping on the hub.
SOLUTION: As a temporary solution glue the feed roller to the hub.
KBA00034433
byronf
04-26-2019, 05:04 AM
Hi,
You should be using part number A64J564101.
rrrohan
04-26-2019, 07:09 AM
i still use A00J on 8 series, no problem so far
Bix
04-29-2019, 04:42 PM
what does "glue the feed roller to the hub" mean? :)
I do not understand what is meant by a hub
tsbservice
04-29-2019, 05:39 PM
It's 'Nabe' in German I believe:D
The black plastic center part of rollers. Imagine feed drive rotates this hub but the rubber roller is sleeping on hub.
