View Full Version : 3253 Jamming in PF 6110
djs9164
04-30-2019, 02:09 AM
Jam is intermittent,more often than not. When feeding using tray 4 the code is 1614 and tray 3 it's 0533. Already tried new bridge drive unit and pwb for the PF7110. The trays 1 and 2 have no problems. Any feedback appreciated.
Sent from my XT1635-01 using Tapatalk
djs9164
04-30-2019, 02:11 AM
Sent from my XT1635-01 using TapatalkTitle should be jamming in PF 7110.
Tonerkiller
04-30-2019, 01:27 PM
That is a multifeed jam. did you adj the sep pressure?
djs9164
04-30-2019, 02:16 PM
That is a multifeed jam. did you adj the sep pressure?Yep. Like ai said even swapped out the bridge unit from another machine
darry1322
04-30-2019, 02:21 PM
Swapping out the bridge unit isn't the same as adjusting sep pressure though. Just so we're clear on what has been tried.
djs9164
04-30-2019, 02:27 PM
Swapping out the bridge unit isn't the same as adjusting sep pressure though. Just so we're clear on what has been tried.Yes I tried the sep. pressure in every position. And the bridge unit I swapped is working today n another machine. On this unit the rollers are all part of the bridge unit.
http://serviceportal.kdaconnect.com/asteaalliance100_self-service//images/ISYS/pdf_sm.gif QA_H102_2ND_0055_SB.pdf This is from the 2 series but may still be relevant to your issue
djs9164
04-30-2019, 03:12 PM
Here is the QAI have seen that too in a report but my unit is way past that this one doesn't even have the polystyrene washers thanks anyways
darry1322
04-30-2019, 06:34 PM
Just wanted to be clear on the sep pressure. Using a different bridge unit might still have the default sep pressure setting (you know, since the rollers are all part of the bridge unit) and still have jamming issues unless adjusted. Different paper stocks might need different settings for sep pressure. I've solved a few multi feed jam issues by reducing sep pressure a notch.
djs9164
04-30-2019, 06:48 PM
Just wanted to be clear on the sep pressure. Using a different bridge unit might still have the default sep pressure setting (you know, since the rollers are all part of the bridge unit) and still have jamming issues unless adjusted. Different paper stocks might need different settings for sep pressure. I've solved a few multi feed jam issues by reducing sep pressure a notch.Went out today with a swapped PF 7110. Found the switch arm in the vertical TX unit was sticking. No reason so I swapped units. All is good. Thanks for the help.
