View Full Version : Error Code LCT Ribbon Cable Torn c-0215
HostileHare
05-02-2019, 08:40 PM
Hey folks, I have a customer with a Konica Minolta Bizhub C360 with a torn ribbon cable in the LCT. I'm struggling to find the dumb cable. Its the orange one the connects to the back of the LCT. Its visibly ripped, casausing a C-0212 code. I need a part number for it, TIA!!
copier addict
05-02-2019, 09:57 PM
It is called a PWB assy. Part number is 4479010503
HostileHare
05-03-2019, 02:40 PM
This is coming up as the PWB in the standard cassettes, the ribbon cable that is torn is in the LCT, is it still the same part?
B0265
05-03-2019, 03:41 PM
That part number should be correct.
HostileHare
05-03-2019, 05:09 PM
Thank you very much!! I appreciate the help!
HostileHare
05-03-2019, 05:48 PM
Ok, i have 7 days before the part comes in, is it possible to disconnect the LCT so the machine will run in the mean while?
copier addict
05-03-2019, 06:11 PM
On the back of the machine there is a small cover in the middle at the bottom. Under this cover there are some connectors. Disconnect these connectors and the machine will work. Be sure to turn the power off and unplug the machine before doing this.
