View Full Version : Miscellaneous How do you see drum and dev Life on C458 ?
omada
05-17-2019, 11:52 AM
Hello all,
Please I need help to find access at the life level of other consummable that toner (drum, dev, transfert belt ... )?
Some weeks that I search on the main panel of my C458 ... I have also service access but nothing ...
Many thanks in advance
Synthohol
05-17-2019, 12:33 PM
Software switch 227 change hex to 00 hit fix.
omada
05-17-2019, 12:47 PM
Thank you for your quick reply Synthohol (http://www.copytechnet.com/forums/members/synthohol.html) ! Could you give me more detail please ? This is firmware update ? or if you have detailled procedure ?
tsbservice
05-17-2019, 02:37 PM
He gave you everything you need IF you are tech.
If enduser with access to tech mode, you shouldn't mess with the things you don't understand.
May end up with good boat anchor instead of machine.
BTW, what's wrong with your C458?
