View Full Version : Error Code PRT/IR L-1 L-2 L-3 L-4 Bizhub C284
Marquee
05-17-2019, 02:34 PM
Hello,
An enduser has a Konica Minolta Bizhub C284 which gives the following errorcode: PRT/IR L-1 L-2 L-3 L-4. We've tried to enter the service mode to reset this errorcode. I don't know for what reason but the normal service password doesn't work.
Can somebody please help us out? Is there a way to reset the service password?
Thanks in advance for your cooperation.
Kind regards,
Marquee
copyman
05-17-2019, 04:10 PM
The "L" codes mean all the drums have reached end of life. There is nothing to "reset" in service mode, new drums have a chip on them that reset the counters. There is a known issue with this machine that if you let the drums run way past their life they can short out crashing the developer unit(s). Developers cost $400-500 each for color units, $150 for black!
allan
05-17-2019, 04:14 PM
What service password did you use?
Marquee
05-17-2019, 04:57 PM
Ok, so if we replace the drum units for new ones (and the developers aren't cracked), you think the system will work properly again?
Marquee
05-17-2019, 05:06 PM
the one that starts with 9... etc.
copyman
05-18-2019, 01:11 PM
Did you try the "9" password 4 times? If not usually 1,2,3,4,5,6,7,8
