View Full Version : bizhub c3350 firmware update
mircea
05-22-2019, 07:03 AM
hello
Any1 knows how to do the firmware update on this machine? bizuhb c3350?
i got bothbizhubC3850Series_Cont_A3GN30G0851-899
bizhubC3850Series_Cont_A3GN30G0851-W99
files but im not sure about the steps i should follow. in service mode machine wont see any files on my usb stick ( zipped or not)
Thx :)
rrrohan
05-22-2019, 08:52 AM
USB needs to be FAT32
needs a folder called 'firmware' in root directory then firmware loaded into that folder as a .prn file
start with A3GN30G0803-899.prn then A3GN30GE8C3-W51.prn then C3350_EngineA3GN0Y00050G002100.prn
Your filenames might differ slightly but the idea is you do sub controller then main controller then engine
Pretty sure you can only have one prn file in the folder at a time. thats how i always did it atleast
mircea
05-22-2019, 06:07 PM
Thank you for replying
And is there any other special usb port besides the one on right side of touch panel?
Thank you again! :)
rrrohan
05-23-2019, 01:31 AM
just the front USB
Also dont put both files on at same time start with -899 then once finished delete it off usb and put on next file
also are you aware of the procedure to start it downloading firmware? Service Mode - Firmware Update - Select file on USB - Execute - OK
Dont touch it until machine restarts
Woxner
05-23-2019, 01:38 AM
you can put all the files on the usb at one time. it should list them when you select firmware update. firmware folder needs to be all lower case
srvctec
05-23-2019, 08:50 PM
That's how I've always done it. Put all different firmwares for the same machine on one drive and then just choose from the list when installing. Never had an issue yet. In fact I think it says right in the book to do it that way.
edit:
Taken right from the book, emphasis mine.
2.1.2
Saving the firmware data into the USB memory device
1. Save the firmware data in appropriate space in the PC.
2. Connect the USB memory device to the PC.
3. Create a "firmware" folder immediately under the drive of the USB memory device.
4. Copy the firmware data (***.prn) in the firmware folder created in step 3.
NOTE
• Be sure to save the firmware data in "drive:/firmware/***.prn."
• The printer can display up to 20 files of firmware data during upgrading.
• The control firmware includes the following three types of file.
Firstly upgrade the sub firmware, and then upgrade the main firmware.
• CntUpA3GN*******-899.prn : Sub Firmware
• CntUpA3GN*******-999.prn : Main Firmware (non-supported for Web browser)
• CntUpA3GN*******-W99.prn : Main Firmware (Supported for Web Browser)
tsbservice
05-23-2019, 09:01 PM
Nobody want to read the books. It's all written by Japanese engineers. Just RTFM.
mircea
05-24-2019, 01:07 PM
Thank you . it worked.
And i dont have the manual for those saying to read it.
But thx for you time! ;)
Enjoy your weekends
ionutzd
01-03-2022, 06:54 PM
Hi,
I just found this thread, can you tell me where did you get A3GN30G0803? I'm trying to find it, it seems that's the one I need to make Airprint and Bonjour work.
I have 3 printers, 2 of them are working perfectly (A3GN30G0803) and one (A3GN30GM8C3) with Airprint and Bonjour disabled (and whatever I do, I can't enable them).
Do you have any hint, what should I look for?
Thank you!
Hi, I find this thread.
where i can get firmware updates for KM bizhub c3350? my one don't print color by wire, (as printer) with driver or with web client, only makes color copies. think i ll cure this with a firmware update or go bad in darkness
copier tech
02-07-2022, 08:02 PM
We'd be happy to help.
Printer & Copier Firmware - www.printerfirmware.co.uk (http://www.PrinterFirmware.co.uk)
Synthohol
02-07-2022, 10:24 PM
or use the correct driver?
TCP/IP raw port 9100
no WSD crap ports.
make sure there are no restrictions on color printing in admin mode.
i really dont see firmware helping your PC print in color.
does it print monochrome at least? you only said color so i cant tell if its printing at all.
is color the default in the correct driver?
lots to check before you just hit it with firmware to fix whats likely a driver issue.
no WSD crap ports.
i've tried several drivers, usb and lan, try print direct through web interface. as result 4 b/w printing different density, think it were color channels by b/w. color copy good. think it mayb software bug and i need to reinstall firmware
divadiow
03-23-2022, 10:29 AM
anything newer than these versions?
Controller ROM Version A3GN30GB883-W51
Engine ROM Version A3GN0Y00050G001800
Boot ROM Version A3GN99G0100-999
Panel ROM Version A3GN02G0152-999
Scanner ROM Version A3GN23G0102-999
copier tech
03-23-2022, 08:49 PM
52672
divadiow
03-25-2022, 11:45 AM
52672
ah, thanks
so, A3GN30GH8C3-W51 is newer than A3GN30GB883-W51.
don't suppose you have the changelogs for all versions from GB883 to latest?
divadiow
04-04-2022, 08:19 AM
ah, thanks
please help! <3
please help! <3
Why do you think you need an update? Any specific prolems?
divadiow
04-04-2022, 11:56 AM
Ysoft SafeQ 6 terminal fails with TLS/SSL error to this one machine. We've another C3350 with the same firmware level but SQ6 pushes out fine.
ALL settings in every config page match the one that does work. We've spent hours on it.
I just want to know if there are any changes in more recent firmware, if there are any, that might fix any issues witb varying controller revisions or anything else. I'm probably clutching at straws but KM are citing the semiconductor shortage still for not offering to replace the unit with another C3350 or C3350i or anther MPF of similar physical dimensions.
Residenttom
08-01-2022, 03:12 PM
Hello everyone, I am a private end user and have purchased a used bizhub 3350 (admin passwords and IT skills available). Where can you download the latest firmware? can someone provide me with this as a download or send a link?
copier tech
08-02-2022, 09:50 PM
Happy to help, drop us an email.
kevinkat
01-30-2023, 05:53 PM
hello, i have a c3350 printer, here is the system settings
I have a European version since I am in France.
if there is a newer version for the printer, where can I download the firmware?
thanks in advance for any response
cordially
Version ROM ContrôleurA3GN30G0607-W99
Version ROM MachineA3GN0Y00050G001800
Version ROM DémarrageA3GN99G0100-999
Version ROM écranA3GN02G0152-999
Scanner Version ROMA3GN23G0102-999
Version ROM de la carte fax A6ED40G1000-999
ROM Version Controller A3GN30G0607-W99
Machine ROM Version A3GN0Y00050G001800
Screen ROM version A3GN02G0152-999
ROM version of the fax A6ED40G1000-999 board
