View Full Version : Miscellaneous Konica Minolta C284e uneven image
mearmi
05-22-2019, 11:02 AM
Konica Minolta C284e image is not straight from Both ADF and Platen glass.
Please find the attached and advise. Original kept as LEF on the ADF and Glass.
Many Thanks and Regards,
allan
05-22-2019, 12:13 PM
Don't think its your platen.
ADF and engine. You test print could be skewed.
Adjust you DF then run the DF setup sheet thru it.
If still you of range adjust you original stop position.
mearmi
05-22-2019, 12:21 PM
Thanks For your reply. There is no problem with printing.
print is fine. Attached is a Scanned image
getting this problem when Scan/Copy. From ADF and Platen Glass is same.
copier addict
05-22-2019, 01:11 PM
The front left corner of the scanner bed is likely sagging. When this happens I will remove the left scanner cover, loosen the six screws and while lifting up on the left corner, tighten the screws again.
If that is unsuccessful just grab the front left corner of the scanner bed and lift up sharply.
rrrohan
05-23-2019, 01:52 AM
its funny how common this fix is. first time i tried it i was shocked that it worked
copytechman
05-23-2019, 03:19 AM
Been there! Done that! Got the T-shirt!
Regards!
A.
blackcat4866
05-23-2019, 12:02 PM
We used to call it the "Ricoh Bear Hug" because it was so common on Ricohs from the 90's. =^..^=
Gaffers01
05-23-2019, 01:03 PM
Agree with the above, but sometimes ive had to adjust the scanner position on the scan cable (front only)
its a bit trial and error but eventually you can get it back to spot on.
